Hi all
Can anyone tell me if the gearbox and diff in the 1800 sierra are the same as the 2.0lt
many thanks
Depends on engine. If the 2.0 is a dohc then no
Most 1.8 CVH Sierras have Type 9 & 3.62 diff, but they do vary from car to car.
Stu
My 1.8CVH Sierra donor came with a Type 9 box & a 3.92 diff, it was an estate version so not sure if that had anything to do with the diff ratio
cheers
andy
My original donor was Sierra saffire and also came with 1.8CVH and Type 9 and 3.92 diff
Adrian
As ^^^^
Gearbox from 1.8 cvh is the same as a 1.6/2.0 pinto with regards to the diff they do vary slightly best thing to do is check the metal tag it will
have the ratio stamped on it
Hope this helps
www.firstmotion.co.uk
