I have an mt75 that i want to marry up to a zetec, what does it involve and what parts do i need?
Zetec has the correct bolt pattern, clutch has the right splines, should fit straight on but might need some webs ground off of the sump to fit the starter
early mondeo clutch 1.8 flywheel .2.0 dohc or 1.8 cvh starter motor and thrust bearing with a spacer like this
http://www.westfield-sportscars.co.uk/shop/product.asp?P_ID=254&strPageHistory=search&strKeywords=mt75&numPageStartPosition=1&strSearc
hCriteria=any&PT_ID=all
[Edited on 30/1/11 by JAMSTER]
thanks guys, is the sump going to have to be modified to go in a GBS zero?
