Continuing on with the sump changeover, can someone reccomend the best silicon type sealer and best place to get it
Halfords sell it. Go and have a look.
Make sure its cat safe if using one or a wide band, most Silicone is not.
Paul
Ford sell small tubes of the stuff they use, it's mentally sticky, but expensive..
i was told the sealant which sets only when it is sealed from air (anaerobic) was best? - so the excess doesn't clog the oil picukp?
the last stuff i used to build an engine was terostat-9220 (henkel) cos i was given it, skoda allegedly use it to stick the octavia roofs on with?
i will let you know when i come to take it apart if i can!
the best advice is not to skimp on sealant.
http://www.locostbuilders.co.uk/viewthread.php?tid=12
6656&page=&contribmessage=none
IC
I bought the Raceline sump and they say to use the ford stuff. With the fitting instructions it gives the part number which I can let you have if you need it?
Loctite 5910 or 5699 off ebay
[Edited on 4/2/11 by britishtrident]
