Will my sump be low enough?
lewis - 5/2/11 at 08:39 PM
Hi all I have a 2.0l blacktop/type 9 going into a MK Indy,will my sump be ok because it's not far off the bellhousing height comments please.
norfolkluego - 5/2/11 at 08:56 PM
Do you mean will it ground?
lewis - 5/2/11 at 09:02 PM
Yea sorry,will I have enough ground clearance when in the car.
jacko - 5/2/11 at 09:02 PM
NO I think dunk3 had to remove about 40mm off the std steel sump
this is Dunk3 car
[Edited on 5/2/11 by jacko]
whitestu - 5/2/11 at 09:31 PM
Yep, you'll need to cut a blacktop sump down to fit an Indy and give enough ground clearance.
Stu
lewis - 5/2/11 at 09:41 PM
Ok cheers guys.
jacko - 5/2/11 at 09:48 PM
You will have to cut the alloy away for the starter too
Have a look at Dunk3 photos it's very helpful
Jacko
RichardK - 5/2/11 at 10:27 PM
Jacko
Starters already on!
