I'm looking for a cable activated heater valve that has a bypass when in the closed position so that coolant still flows. I've had a trawl
through fleabay but the valves from modern cars are electronically operated so not suitable unless modifiable.
Does anyone know of a suitable valve?
cheers
Jed
Classic range rovers have a vacuum operated one but you can crack the top off the piston and attach a cable easily...
http://www.locostbuilders.co.uk/viewthread.php?tid=149204
Try this
