Guess who didnt put anti freeze in the coolant system. Fortunatley this is the only damage.
Lucky to get away with it if thats the only damage. Check all the core plugs haven't moved. Always use anti-freeze/coolant. It's anti-corrosive and lubricant properties means it does move than just stop freezing.
i guess you!
It also improves the heat transfer so it aids cooling in summer. That's why the full title is usually "anti-freeze and summer coolant"
It's a good thing (unless you drink it).
My mate split the block on his newly rebuilt £2K rover V8 because of this. It goes with out saying he was upset!
I dont understand why people dont put anti freeze in out of principle.
Should have kept it in Pats garage like I did. 20'c for 24/7 you dont need any anti freeze.
Moss
