Hi all,
Quick question to anyone who has an 2000-2002 model ZX12 engine - on the fuel rail there's a flow and return fittings. Which one is which ?, is
the flow (ie fuel In) the one closest to the clutch, and the return to the tank the exit closest to the prop shaft ?
Tris
Not familiar with the ZX12 but normally return is from the end with the presure regulator fitted.
Hi fuel in is direct into rail on left fuel out is after regulator on right
cheers mal
