Hi guys.. just wondering which clutch cable people use for an MK Indy Blade ???
Also what the best was to secure cable at the peddle end ??
Had a bit of a cable slip when out today.. and the clutch peddle was rendered useless. managed to bodge the cable but now wanna tray and sort it so it
never happens again..
TIA Alan
Standard blade clutch cable for me, when I made the pedal I welded a cup with slot to match that of the bikes handle bar levers so the cable end rolls
within the top of the pedal arm.
Set the pivot so full throw is full movement on the bile casing, nice light clutch.
Regards Mark
