Indy Blade first gear knocking
tompat3463 - 27/3/11 at 02:47 PM
hi, is it normal for first gear the be knocking when driving in it.. for example , if im in traffic and a wanna go slow ill drive in 1st gear but when i let off the throttle or put my foot on the throttle a little bit the engine will knock with the revs if u can understand me ??
TIA Alan
johny p - 27/3/11 at 03:35 PM
hi mate.. check the flange bolt going to the gearbox flange is tight.. this is a common problem coming loose on the blade engine.. normally caused if the prop isnt properly aligned....
Johneturbo - 27/3/11 at 03:39 PM
Could it be backlash in the diff?
johny p - 27/3/11 at 03:42 PM
that could be another cause yes.... needs looking at tho..
mark chandler - 27/3/11 at 03:59 PM
It's almost impossible to coast in first gear without it snatching, as the car jerks your foot jerks on the pedal and it gets worse.
If the carbs are a little out of balance then this makes things worse.
Have you got a lot of throttle pedal travel, again only a short push makes things worse again as it will be very sensitive to small movements.
Regards Mark
van cleef - 27/3/11 at 05:18 PM
I'm with Jonny p as mine was knocking a little before the prop came off the gear box at 70 mph and turned my engine into spares.
