Hi,
I have been trying to re-pack my exhaust but when I took the end cap off, I noticed that the perforated tube has broken and needs replacing however I
can't get it off the exhaust.
I thought that it would be best to heat up the exhaust to hopefully loosen it up, is this the best idea or is there a better method or removing the
tube.
Any advice would be great.
Last one i did i had to twist it backwards and forwards and pulled it at the same time
Eventually it came out, but it was tight (BTB Silencer)
