Which throttle bodies are the same width apart as zx9r b1 carbs?
rich201283 - 24/4/11 at 09:21 PM
matt_gsxr - 25/4/11 at 07:39 AM
I don't know the spacing on a zx9r but here is great thread listing the sizes and spacing of existing throttle bodies.
http://www.msextra.com/forums/viewtopic.php?t=6627
Just measure up and see which is best.
I would have thought you'd have a lot of options.
matt_gsxr - 25/4/11 at 07:46 AM
googling suggests your spacing might be 75-75-75mm so zx6r TBI's perhaps? You want integrated injectors and fuel rail so make sure you get some with that (i.e. some Honda don't do this).
Measure a few times before hitting the "buy it now" button.
coozer - 25/4/11 at 09:18 AM
Are ZX9 carbs not 80mm between centres? The ones I have are....
FASTdan - 25/4/11 at 09:21 AM
Zx9's vary, Ive done manifolds for them with various spacings.
coozer - 25/4/11 at 09:28 AM
Just checked...
ZX9R carbs above are 78mm between centres...
Fireblade TB's below are 80mm between centres and the inlets are a much bigger diameter too.
