manual or auto blacktop
gavin174 - 9/5/11 at 05:03 PM
Hi all
does anyone know if the 2.0 zetec (blacktop) auto is the same engine as the manual...
or is it lower compression
cheers Gavin
doddy - 9/5/11 at 05:13 PM
i think the flywheel is differnt you will need a maunal one
gavin174 - 9/5/11 at 05:15 PM
of course.. didnt think of that..
torque converter and all..
but what about engine internals..
big_wasa - 9/5/11 at 05:19 PM
As far as I know internals are all the same, ecu map is the differance. The Crank Position Sensor Housing is differant and will need swaping over.
gavin174 - 9/5/11 at 06:35 PM
anyone have a spare Crank Position Sensor Housing?
would this be what I need
FORD MONDEO MK3 PETROL CRANKSHAFT CRANK POSITION SENSOR | eBay UK
[Edited on 9/5/11 by gavin174]
big_wasa - 9/5/11 at 06:43 PM
No thats a duratec sensor. Its the housing thats differant on the zetec.
gavin174 - 9/5/11 at 06:46 PM
thanks for the fast replies...
will have to check if there still available from ford then.
L5W - 9/5/11 at 08:15 PM
Hi,
I have the housing from a silvertop which you're welcome to. I'm not sure if its the same as the blacktop one though.
Lee
gavin174 - 9/5/11 at 08:19 PM
I think the part no. I am after is 928F-6K341-AF
http://locostbuilders.co.uk/forum/9/viewthread.php?tid=140115
mcerd1 - 9/5/11 at 08:20 PM
I wouldn't bother with ford, its bound be out of stock and cost a fortune
even if L5W's ones no good there should be loads of manual blacktops in the scrapyards and I can't see them charging much for one of them
(ps - do you fancy pick up a speed sensor for my focus while your there )
[Edited on 9/5/2011 by mcerd1]
big_wasa - 9/5/11 at 08:39 PM
Its only one bolt to remove it BUT thats after you have removed the gearbox and flywheel.
