will standard blacktop inlet man.fit st170
subevo - 12/5/11 at 05:14 PM
can anyone confirm that a standard blacktop inlet manifold with single throttle body would fit an ST170.
reason being ive just fitted a rotrex supercharger to the st170 and just realised that on the omex website they do a fully mapped ecu for the blacktop engine with rotrex. therefore if i could retro fit the blacktop manifold i could get this ecu to work.
i spoke to a software guy at omex but he thinks it wont fit.if i can prove it . then i can get one by copying what they have.
[Edited on 12/5/11 by subevo]
HowardB - 12/5/11 at 05:19 PM
the st170 inlet fits the 2.0 zetec, so it ought to work the other way. I hope to have a steel inlet with a single TB spare soon.
cheers
FASTdan - 12/5/11 at 05:47 PM
It will physically bolt up.
However, the ST170 ports are approx 2mm higher up (bottom edge) and then overall about 4mm taller. Therefore you may find there is a 2mm lip into the head on the bottom of the port. Not the end of the world.
subevo - 12/5/11 at 08:48 PM
thanks guys.ive just realised ive got a 1.8 blacktop inlet in my scrap pile.might check it out tomorrow.
next question . does anyone know if there is there a difference between the 1.8 and 2.0 blacktop inlet manifold or are they the same.
