anyone running an oil cooler on a c2.0xe
ive just been given one , its a little bigger then the stock one ( not much )
will it be overkill or o/k ?
I've not fitted one on mine, you don't need it
Never needed one on my XE.
If you do want one, just make sure you fit a thermostat then it wont cool to an unnessacary level.
I have one on my 230 hp engine and turns out i didnt need one after all!!!
Dont bother....
thanks for that chaps
will it harm it? ihave one and its needed on hot track days
Its a good idea to monitor the oil temp before deciding *if* you need to fit an oil cooler and also keep an eye on oil pressure (make sure your using
the right spec oil)
*If* going for an Oil cooler it needs a stat really so there's no danger of 'overcooling' the oil
as said above most folks don't need one but if your running a fairly high spec or turbo motor and doing track days etc
its worth checking oil temp and then making a decision
Run a Laminova on mine which helps bring the oil temp up to the right level
