HI,CAN ANYONE PLEASE HELP,I HAVE JUST PURCHASED F27 WITH 2LTR PINTO AND TWIN 40 DELLORTO DHLA TYPE F CARBS.VACUM DISCONNECTED.WHAT DEGRES REQD FOR TIMING AT 1000 RPM ,THANKS
What cam?
8deg for a standard cam. 12 for fast road, 10 for mild.
I prefer to time it 'all in' rather than at idle.
Get someone to raise the engine speed until the timing is fully advanced and time it to 36 degrees with the vac disconnected.
Take it for a test drive, if it pinks then back off a little.
12° for unleaded fuel, that's what I had to run mine anyway. It does seem to vary from one engine to another and they all seem to have a sweet spot which you might have to experiment to find.
