a long way off needing to fit an upgrade engine and still learning about it all but been looking over options. Bike engine would be nice but insurance
would be very steep, a played about zetec or maybe duratec hmmm me nice an quick but came across duratec v6 assuming its the mondeo st24 engine and
would be noce and diffrent may sound a bit meaty too so anyone done this or have this engine in a car or kit. Come on people through in the opinions
and ideas
Was even wundering what mods would be nice for a v6 nothing silly money tho.
No help from me with the V6 Duratec but I'm sure Clairetoo can tell you stuff!
I'm fitting a duratec v6 from an s-type at the moment.
link to write up
To me it seems to be the perfect engine for a kit car, compact, lightweight and powerful (240BHP out of the box)
Cheers guys its a fair way away.but just looking it all over, I didnt think a v6 would be light weight but then again pintos a brick. Also in the pictures did you change the jag rocker covers for ford items.
Depends how much pioneering you want to do, I have gone down the inline 4 Duratec route and to be honest enjoyed doing it -but because it is not the
popular choice yet, sourcing parts and info is the hardest bit, and there is quite a bit of information out their.
It is also a very expensive way to go.
I can only think that the V6 route would be even more expensive and frustrating.
If you are going to put 240HP down the Sierra drive train you will need quite a few upgrades here too.
Currently theirs a few under £250 on the ebay, and thinking of a mt75 but may need some mods any ideas??
I think the V6 Duratec is underpowered for what it is and expensive to sort out. A V12 Duratec might fit the bill, but a bit expensive.
Plenty of lightweight V8's out there, Lexus, Merc, Audi etc. Lots of go for you money.
The Duratec is not the smallest of engines either. Claire has the Mazda KL 2.5l V6, and it's tiny. It's also what I'm going to put into my Sprite. 200 or so BHP with the usual kit car mods and it'll rev to 8K almost all day long. Its also cheap as is the gearbox, which is/was a stumbling point with the Duratec as it needs the Jag box.
These guys have it bolted to a mid engined lotus esprit via an adaptor plate. I would think an MT75 could be fitted the same way. Doesn't the
mtx75 in transits have a removable bell housing.
lotus site
I have a bell housing which bolts to a type 9 bought from the company that supplies Morgan and noble. The standard type 9 would give up fairly quickly
but the uprated 4x4 gearbox could be okay (with standard tail piece) and the longer input shaft would be an advantage. Mine has the caterham input
shaft with quaife internals.
the engine has the standard Jag cam covers. Go for it then we can compare notes
Once storage for car n bits is sorted ill be hunting down a new engine and the v6 duratec looks like fun so ill begine research now and find od bits that ill need to know of for when it comes too it. As for the mt75box I was looking at either a transit or 4x4 as was assuming itd take better than std mt75 or my type9.
Duratec V6 with an mt75 box
And a Pug V6 bolted to a type 9!
I was wundering this but some people say their are some that may fit from the bigger engines but dont know myself, have been offers a full engine set up for under £200 deliverd to my door has everything from the vehicle including key n barrel with only around 40k on the clock. Think im going to take the offer and gather parts and info slowly for it.
..........and a KL V6 bolted to an Mx5 gearbox
That Mazda v6 looks tidy!
How far forward in the chassis did you have to fit it to get the gear lever in the correct position? I looks like a massive distance from back of
block to gear lever
How far forward in the chassis did you have to fit it to get the gear lever in the correct position? I looks like a massive distance from back of block to gear lever
That looks great but the duratec so far wins it for me the white std inlet manifold adds to the style any one have any measurements for the diratec, ie hieght what sump to use length withoutqcx n width with and without all auxilaries.
Thankyou very mich for help I am going direction of spacing plate to seal spaces and get a better fixing point, would an mt75 be better as moderner inturnals and easier for parts especial a diesel transit one as my type 9 I think would go pop with the power and dont want to go high modifying its internals as its an old box.
Engines coming saterday afternoon £170 including delivery
