Does anyone know the size of the jets to best use on a 1300 crossflow? I have lots of jets but not a clue! also i have this on my engine but dont know
if i need to connect this to anything or what it is exactly
Originally posted by killieaitken
Does anyone know the size of the jets to best use on a 1300 crossflow? I have lots of jets but not a clue! also i have this on my engine but dont know if i need to connect this to anything or what it is exactly
No problem, so since i have installed a new fuel pump (high performance) i take it the factory fitted one is no longer needed?
Take the pump off and stick one of these on.
http://www.burtonpower.com/fp281.html
cheers Brian, i take it this needs to be done to ensure good running?
[Edited on 25/1/12 by killieaitken]
It won't affect the running but is wasting engine power as you will still be operating the mechanical pump but just trying to pump fresh air!
It would be cheaper to leave it on. The drag on the engine from this pump is negligible as it is pushed by a cam on the camshaft (or crank, i forget which now) not turned like a power steering pump.
cheers i found a company that produced a blanking plate for £2.50 delivered! Was a 2 minute job
