Good evening everyone,
Started to look at making a connection between throttle pedal and the ZX6 Carbs and
there is no simple way of locating the cable outer.
Is there something missing?
carbs_throttle_connection
Any comments / pictures greatly received.
Thanks,
Len.
yes, from memory theres a plate that bolts onto the mounting above the choke plunger in the pic
Yes a bracket missing,sits about 2"above the throttle linkage
Another pic of the bracket from the side
Thanks,
That explains why the top screw was not tight!
Any ideas where I can get one from?
Len.
Edit for double post,you could make a bracket,only needs one cable holder just copy the shape of the ones pictured,failing that eBay or bike breakers
online?
[Edited on 31/1/12 by lewis]
Thanks Lewis,
Looks like my next job is a bit of intricate metal work
Len
I may have one you can have I will look in the garage for you, give me an hour
[Edited on 31/1/12 by stevec]
Thanks Steve,
I will be patient.
Len.
I found these three, you are welcome to any of them you may be able to adapt one.
Steve.
Hi Steve,
U2U sent
Len.
[Edited on 31/1/12 by avagolen]
I've only just seen this thread, so sorry if its too late, but I have a rotten set of ZX6R that I use for spares. That very bracket is available if you'd like?
Hi Deezee,
Yes please. Save me some work.
U2U sent.
Len.
