RE-Pinto Set up
Tinks1 - 1/3/12 at 12:50 PM
Hi Guy's
Following on from my post earlier regarding the "TAK TAK" noise on further investigation I have
tracked it down to Cylinder No1, more luck than management, I have found that if I remove the
No1 plug lead the "TAK TAK" noise disappears, I have tried with all the other pots and this makes
no difference, I have changed the plug leads and spark plugs, and only by removing the no1 lead
does the noise disappear.
Any help appreciated
John
Daddylonglegs - 1/3/12 at 02:56 PM
Little Ends possibly? No firing means no load on the little end.
That's my 2p worth
snapper - 1/3/12 at 04:04 PM
Exhaust leak at the manifold face often sounds like a Tak Tak.
mark chandler - 1/3/12 at 07:11 PM
I,m still with the follower retaining spring, have you looked at this ?
Tinks1 - 2/3/12 at 12:49 PM
Thanks for your responses .... It was a cracked exhaust gasket, relaced all OK
