zetec silvertop rwd starter motor type confirmation??? i just want to confirm the best type to use
if my engine is a good y r
preferably i'd like to use one that does'nt requie a spacer so its as per the factory wanted it in a sence!
i have one number which i think is
lucas lrs707
i have been informed that the sierra cvh/dohc starter motor is a good choice
the pinto starter needs a spacer apparently but i dont really want to go that route, i nearly have all i need to get my engine together in my test rig
to connect all the bits n bobs to to see if i can make it fire up!!!
i'm eager to find out if my engine is a goody or a baddy LOL
FORD SIERRA/SAPPHIRE 1.8 CFi CVH & 2.0 DOHC 91-93 STARTER MOTOR ST323R | eBay
S845 Granada Scorpio 2.0 Sierra 1.6->'DOHC 88-91 Starter | eBay
if its any help my plan is to use a 2.0 silvertop zetec to a 1.8 flywheel (not sure on the clutch yet) alloy rs2000 bellhousing to a campri 2.8i
gearbox
hope this is the info that helps
I believe that is correct. I used the starter than came with the CVh engine in my Sierra, and that fitted my Zetec / type 9 with no modifications
except grinding the usual bits off the Zetec sump.
In fact I need a new one as well cos mine is getting a bit tired!
Stu
This is the one:
Ford 2.0 Zetec Pinto Type 9 Gear Box New Starter Motor Kit Car X-Ref: LRS707 | eBay. Not a bad price either.
top chap stu, need to get m order for one in
CVH Starter: Starter Motor Ford Sierra Sapphire II 1.8 10/89-09/91 | eBay
[Edited on 16/3/12 by loggyboy]
