Hi Folks I need your help again folks,i have aquired a 80% built Indy with a Zetec black top in it,it has the 2 peice sump on it on to a MT75 box.The sump and bell housing are about 3/4 inches below the level of the floor. 1,, is this normal and if not what do i need to do, thanks folks
I have the silvertop in mine the sump is around 3 1/2" from the floor gearboc is a type niine and sits below floor level so sounds about right
But avoid bumpy roads. I fried my engine hitting something, losing oil and pressure.
My indy has a blacktop and is about
the same.As said,go easy over the speed bumps.
