[img]
[/img]
Dose anyone know the correct way to connect up the oil feed and return. I have an oil cooler , can it be connected in series with that some way? or
dose it have to have a free flow return? Thanks. (its an 1990 zx10 engine)
The returns on the turbo production cars I've owned always goes directly back into the sump.
Worth checking that return pipe occasionally as they tend to cook & then split partic. the side nearest the turbo - ask me how I know!
HTH.
Cheers, Pewe10
as above it should go strait back in to the sump
So that's the term free flow return ive come across?
Yes, backl to the sump but it should be under gravity of as you say "Free Flow". Be careful with hoses. The renault 21 turbo guys have had a few fires because of split / perished hoses.
If you have the turbo super low like is often needed on a bike then you may need to pump it back up.
Some folk built mechanical pumps or you can get electrical versions.
yeah was wondering about that. if its free flow can it go in at the bottom of the sump or dose it have to enter higher and drain down? my installation the turbo is still above the line of the bottom of sump?
The renault 21 has the return entering higher than the top of the sump.
I will be using it for racing for lot of oil sloshing around sump. Is it possible to pipe it back up to the rocker cover or somewhere like that?
Gotcha now!.....is there any way of identifying the flow and return on Garrett turbos? mines from a 2001 saab 93.....i got it from a breakers yard so didnt see it being removed?
You can normally loosen the turbine and compressor housings to align the parts as required (with the oil drain pointing vertically down). You may
have to modify the wastegate actuator bracket after doing this however.
[Edited on 15/6/12 by MikeRJ]
On my zx10r turbo (Velocity racing turbo kit) the oil feed came from the main oil gallery, there's a plug to remove, think it was 3/8 NPT, for the return to the sump, I drilled a hole as low as possible in the sump, used a pipe fiiting with dowty washes to seal it.
Originally posted by MikeRJ
You can normally loosen the turbine and compressor housings to align the parts as required (with the oil drain pointing vertically down). You may have to modify the wastegate actuator bracket after doing this however.
Thanks lads. Id love to see some pictures of your zx10 Paul.
If I put the electric pump on the oil return line will it still be a free flow retun since it is being "pumped" back into sump?
ok in a bike, but can't take the extra stress in a car.
.jpg)
.jpg)
That sounds a bit worrying!!!........what sort of boost pressure were u running? Was it at standard compression?
Only ran 6/7 psi, standard compression, thats what Velocity run on there stage 1 system.
Well I can say that a STD engine will be ok o around 6 psi max 4 psi would be better, anything after this as Paul said rods will need replacing, I
replace rod pistons head gasket, valve are also a point o weakness 2 bent in Pauls engine,
We ran 9 psi and was fine the engine only gave up after 3500 mile as he new owner blewup on track well span a Bearing due to him not monitoring oil
temp, killed it r a 20 plus lap stint at Oultan park,
Only him sl to blame othe than that it's all fine no and runs 340 bhp at 12 psi,
I can and pics or may be some in my archive I you take. Look,
I owl invest in an oil cooler though for sure,
I have some STD rods and pistons also in the garage in very good condition an may sell them on if neon interested?
Good luck,
Sean
Originally posted by PAUL FISHER
Here's a video of Seans when he had worked his majic on the engine![]()
http://www.youtube.com/watch?v=yqV3ipH-1X0&feature=results_main&playnext=1&list=PLACED24E4B74C743D
Sorry lads if i hav'nt made it clear, my zx10 is the 1990 model.....i have it running it on zx6r throttle bodies with MS2 extra at the moment.
The standard c/r is 11:1 and im using a good big oil cooler off a newholland tractor.
OH ok sorry about that, not sure about the olders zx10 so don't take any advice I've given as don't know if they are the same,
Good luck
Dose anybody know where I can get one of those electric oil pumps from. And how much should I pay for it?
FBM on oldskool suzuki can supply.
There are a few thread, but this one is a start.
http://forum.oldskoolsuzuki.info/cgi-bin/Yabb/YaBB.pl?num=1327063015/0
Should the oil supply line for the turbo be taken off the pipe going to the top end of the engine?
