hello
would anyone know where i might get the electrical term to fit a 2 prong reverse switch
Scrapyard usually.
Failing that I reckon some 5mm or so bullet connectors, or just solder and heatshrink should do the job well enough.
mine are solder on, and then two short lengths with spade connectors on, that means that the wiring is easy to remove at a remote location.
hth,..
hth,..
Originally posted by Staple balls
Scrapyard usually.
Mine had a couple of female bullet connectors on it.
all sorted chaps thanks to everybody
