Having a senior moment during the rebuild and cant now remember which way round to plumb the Weber Fuel Pressure Regulator, its one of these:
Anyone jog my failing memory?
Usually the 8mm bottom connection goes to the return line, the middle 8mm connection goes to the fuel rail or carbs. The little connection on top is
the vacuum connection.
[Edited on 14/7/12 by Ben_Copeland]
tvm
