I'm in the process of putting an RST lump in a Dutton Phaeton. With the help of a mate we sorted the gearbox mount yesterday. The next step is making the engine mounts, I have already made the plates that bolt to the engine and have bought some of the big landrover rubber mounts. Question is can the engine sit level or does it need to be tilted in one direction at all?
Pete,
IIRC the bores are verticle in the RST so you should be ok with it straight up
Cheers! that's how I had mocked it up but then had a sudden thought whether it was ok or not
