Hi
What injectors should i use. Zetec with jenvey set up.
Cheerss
depends what power output your looking for , I thingk the standards will be enough as you will probably be getting around the 165 - 170 BHP figure
Can the standard injectors be used in jenvey tb's ??
Beige vauxhall red top 2.o ones are a good choice
But will standard zetec injectors fit in jenvey tb's
I gonna buy a new zetec blacktop engine complete with inlet, so can I use these injectors
Greets
Bas
