Hi all,
Doing a few jobs on the car and to improve the gear change I thought a nice quaife lever on eBay would do the trick. Nothing is ever
straight forward and the lever does not fit. I have a Westfield type 9 gear lever extension plate but I expected the quaife one to fit straight in.
Anyone had similar issues fitting a rose jointed lever.
[img]http://
Quaife gear lever
[/img]
Hi.
Quite a few years ago I fitted a Quaif quick shift to a type 9 i had in a MK2 Escort. I had all sort of grief getting it to work and ended up having
to pack it up with washers to get a satisfactory result.
Regards
Jon
You can see from the picture that the collar is too big to go through the hole in the extension plate.....
Have a look at David Jenkins website, it shows how to make a standard Sierra gearlever into a quickshift for pennies. Sorry can't help with the Quaife item but have used a home made item
Ok thanks... I will have to make a few measurements and get it machined I guess....
Dave b
or flog it to me
Sorry going to make it fit!
got to try
Let me ruin it first then I'll let you have it :-)
