Hi people I've got a 1300 cross flow going on to a type 9 gearbox which clutch do I get??
IIRC I used a 1600 Sierra clutch on my 1600 xflow. My local motor factors were very helpful
When I swapped from a Type 2 to a Type 9 I only changed 2 components, the drive plate from one with a 7/8" 20 spline centre to one with a 1"
23 spline centre plus the release bearing to a standard 5 speed one. Got the clutch plate from Burton since I am pretty sure Ford never actually did
one. Not cheap but a simple solution.
http://www.burtonpower.com/parts-by-category/transmission-clutch-wheels/clutches-std-performance/clutch-plate-ford-ohv-type-1-x23-190mm-cp2257-9.html<
br />
Don't forget the speedo cable, the 4 speed one is too short.
[Edited on 27/12/12 by Paul Turner]
Cheers Paul. Already got the type 9box in with electronic speedo just need the engine, so that's why I needed to know the clutch.
Cheers steve
