just aquired a raw striker chassi and loads of parts has anybody ever fitted a ford puma 1.7 vvc zetec se engine ??
Got a whole puma if you want one?..
Ok m8, Puma's do have great engines...
[Edited on 28/2/13 by ludsonline]
A few have fitted them to sylva j15's, and mojos. I'm in the process of fitting one to my j15...if you read the start of my blog you can find a fair amount of information on them........as far as I know great little engine, and very very light and compact...decent sump, and gear box ratios in the puma are a little closer than a fiesta.
Originally posted by chaddy44
just aquired a raw striker chassi and loads of parts has anybody ever fitted a ford puma 1.7 vvc zetec se engine ??![]()
Hi
Yup, quite popular in the Hillclimb and Sprint community as the class split is 1.7L for the roadgoing kits, plus can be pursuaded to make a lot of
power.
The special addition racing puma had 150 bhp so shouldnt be hard to tune.
Set of individual throttle bodies and you will have a cracking motor! Altetnative is the racing puma manifold.
1600 much cheaper and easier to tune and not VCT to worry about.
lightest 1600 production engine, that what i use in my car
Yes , I've been running one for two years, very good, light, revvy, motor, it has got standard injection and type 9 box.
I built my own bellhousing using the front bit of the standard puma gearbox casing welded to the back bit of a v 6 alloy bellhousing, this works well,
but as mentioned above, you can buy one from various sources.
I would reccomend it, the sump is a bit deeper, with that weird extra cover on the bottom, but you can make it poke out of the top a bit to allow for
it.
It is a simple installation and apart from the bellhousing, it should'nt be any more expensive than a zetec E.
feel free to u2u if you need help.
has anybody got any pics
blackfingernail any pics of the bellhousing would be appreaciated
I built my own bellhousing using the front bit of the standard puma gearbox casing welded to the back bit of a v 6 alloy bellhousing, this works well, but as mentioned above, you can buy one from various sources.
I would reccomend it, the sump is a bit deeper, with that weird extra cover on the bottom, but you can make it poke out of the top a bit to allow for it.
I'm going out for a ride today, so I'll get some pics when I get back.
Do you just want pics of the bellhousing?
I've just put some pics on my photo archive, I dont know how to post them on here. (I make things, I dont play on computers).
The bellhousing is quite buried but I'm sure you get the idea, by the way where are you?
I made the bellhousing, so I suppose its a 1off.
I used the standard ecu. I try to keep things as simple as possible.
Sorry I meant to add,- the pic is of the bottom of the bellhousing, it is the rear part of a v6 unit so it has a ribbed section, my sump has the extra cover on the bottom to give it a bit more capacity for the 1700.
Ahh...just had another look, I thought the bell housing was the sump..doh...yes, same as mine.
many thanks for the pics![]()
i'm in doncaster south yorks
im near wakefield and run a sigma motor, your welcome to have a look and a chat, or if you want pics ive got hundreed of the build
