My car fits MK Indy body work at the front (I think this is the same size as Ron Champion?!) I bought a polo radiator, the wider one of the two and it
is too wide. Does anybody know if the narrower one will fit? i.e. SEAT AROSA 1997-2004 / VW LUPO / POLO 1994-2001 RADIATOR NEW - 2
YEAR WARRANTY | eBay
Or what rads have you fitted? Its for a silvertop locost.
Thanks all
I run the updated alloy rad MK sells and frankly it is too large, In addition to my engine electric pump barely ticking over I had to add blanking to the radiator - it is too big IMO and the car runs too cool. Have you thought about trying a hayabusa radiator?
It's the narrower one you want. There's loads of people with them
Hi we used the small polo rad & it fits fine
The only thing was we had to cut off the small
plastic outlet on the top left hand side, just araldited a
self tapper in the hole
good luck
René
Waterworks R1 Indy
Manufactures fit thermostats and by-pass connections for a reason the thermostat controls the cylinder head temperature within quite close limits and the by-pass keeps the bottom of the cylinders warm and avoids the formation of hot or cold spots.
