Evening all,
Does anyone know the correct torque settings for the following on a 1600 X Flow?
Main Bearing Caps
Big end Bearing caps
Head bolts
If you are not sure, does anyone know where I can find the correct settings?
N
Originally posted by Nickctp
Evening all,
Main Bearing Caps 55-60 lbf.ft (75-82 NM)
Big end Bearing caps 31-35 lbf.ft (42-48 NM)
Head bolts 5, 21-31, 52-56, 66-71 lbf.ft (7, 28-42, 70-76, 90-97 NM) Tightened in stages with the last after 10 to 20 minutes.
Recheck after engine has been warmed up for 15 minutes at 1000 RPM
N
