megajolt and duratec
jacko9370 - 28/4/13 at 10:12 AM
Setting up megajolt on to the duratec.
The trigger wheel VRS, is the standard ford one compatible or does it have to be the one that came with the kit?
lewis - 28/4/13 at 11:07 AM
Rob what flywheel are you using? On the back is the ford trigger wheel & uses the sensor
jacko9370 - 28/4/13 at 11:09 AM
got the standard trigger wheel
Just want to use the standard sensor not the one that came with the megajolt kit, saves making up a bracket when no need
