A std Duratec has 145hp.
A custom manifold, bike carbs, new ECU (like megasquirt), setup, tuning etc.... costs easily £1000 + - to gain a further 25HP.
Is the difference so dramatic to make it worth?
To gain 50HP, you need to spend another £1000.
Why not stick to the engine how it's pulled from the Mondeo - and keep the factory inlet/injectors etc...?
Any reason why this is not a good idea?
THX!
Hi and welcome to the forum.
£1000 sounds about right for the set-up you're referring to. Thats about what it cost me to stick gsxr Throttle bodies on with an Omex 600 ecu
(second hand for £500)
However I gained more like another 45bhp (rolling road came in at 188.9) So more than worth it.
Using the standard ECU wasn't really an option for me either, 1 - I didn't have one and 2- would have been way overcomplicated for me.
My engine also never came with the inlet, there's not reason you cant use this if you have it.
Hope that helps
The idea is fine
The main problem is PATS in the original ECU means you have to stash the original dash somewhere
Any old engine can make 145bhp easily so most spec up the Duratec to 190bhp
No reason not to use factory EFI as recovered from the car if you are willing to undertake the additional complications such as PAT's etc, if you use a system that has been cracked for remapping you can pull additional power with controls such as knock sensors included but in general to go to throttle bodies and to start to really exploit on a budget then standalone may be easier in the long run.
Many thx for all this great advice.
Also, I noticed that carb kits for ZETECs are substantially cheaper - e.g. Ford Zetec E Complete Bike Carb Conversion Kit R1 40mm
Mikuni | eBay
Is there a fundamental reason why it's cheaper to tune ZETECs than Duratecs?
Originally posted by snapper
The idea is fine
Also, I noticed that carb kits for ZETECs are substantially cheaper - e.g. Ford Zetec E Complete Bike Carb Conversion Kit R1 40mm Mikuni | eBay![]()
Mazda 3 engines are ; 148 hp @ 2 liters , 155 @ 2 liters and 167hp @ 2.5 liters, Showroom Stock.
Unless already owning the Mondeo derived engine ? A V good choice imo.
The Japanese units are widely viewed as superior/assembly builds.
Really easy to source as well..On this side of the Atlantic at least.
[Edited on 16/5/13 by Bare]
Many people have followed the Zetec route much less Duratec - suppose its supply and demand
You need deep pockets for Duratec.
FastDan on here has bike carbs on a Duratec
[Edited on 16/5/13 by big-vee-twin]
