Finally got my fireblade carbs running ok, once I found the air leak.
Its on the standard jets which are 120 ive been recommended to go to 130,untill I get it for a rr session but which bit is the bit I need to
change
http://farm8.staticflickr.com/7043/6908661532_5cc989d354_z.jpg
the main is the top screw on this pic. but do I simply change the screw bit or the hexagonal bit it screws into as well.
cheers in advance
you just need to change the screw part not the hex have you moved the engine breather from the airbox to a catch tank as that will make a few more hp
cheers dude. engine breather has been in a catch tank since day one.
now to get jets fitted then rr session.
