So, I am about to try and sell my full fury pinto outfit again, and have unboxed the alternator from where I stored it over winter.
By storing it, I mean putting it in a plastic sealable box, with some other stuff. one of the things in the set of 'other stuff' was a steel
door hinge. They were touching. Here is the result, for your amusement:
don't do this at home
It's so mullered the pulley won't even turn.
Ohh that'll clean up ok
Thought steel rusts to save aluminium?
Wasnt that the problem with old landys? The aluminium body always looked good, but the chassis rusts and protects it?
A Pinto in my part of the world is regarded about equal to a fresh pile of Dog Poo.
Move on.. a Pinto in it's entirety, is simply scrap metal, by any descriptor.
Na it's actually the other way round, the steel rots the aluminium body very badly often cutting holes right through in the shape of the steel bracket and the aluminium turning to white powder, why when they knew of this they didn't simply put a gasket between the to?
Oh well Mr Bare. Its a pretty rapid pile of dog poo then!!!! What you using, a Trabant engine maybe?
Worry not. I'm sure most folks on here can take Bares contributions and opinions for what they are.
I'm not convinced the steel door hinge was entirely to blame considering the alternator is bolted to a steel bracket!
You don't get bi-metalic corrosion without introducing some moisture though.
