Any ideas on the square filler plug size on the type 9, as I need to buy a tool to remove it so that I can top up the oil.
Mathew
I use a t-bar from a weird old socket set my dad has had for 40 years - it seems to fit all the ford stuff
I think its a 5/16" drive (so about 8mm) but I'll check later
failing that I just use one of these:
1/2" square rachet + extension.. Simples...
Mine is a allenkey 10mm i have just done my oil
Jacko
I have a Laser set that came from Halfauds (I needed it on a sunday afternoon).
With hindsight, a cheap ebay kit would be fine I would imagine.
http://www.ebay.co.uk/itm/5pc-Car-Axle-Gearbox-Oil-Sump-Fill-Drain-Plug-Key-Set-/271137011511
