Hi,
Does anyone have a picture of the internals of a Sierra LSD?
Hi Graham,
The Sierra V6 Haynes manual shows cross sections of both types of diff. You can identify which one you are looking at from this.
Mark
[Edited on 17/10/04 by mookaloid]
Don't have one
Buy a haynes manual then
Here you go. Without LSD:
With LSD:
Couldn't help myself - stand by for some auto engineering porn -
bought myself an ATB to go in my sierra diff.
I've stopped calling it a locost.....
here it is from another angle
Mmmmmmmmmmm nice one Bob
What a show off!!!!!!!
But....Hmmmmmmmmmm nice
If I had one of those I'd want to show it off too
How much does one of those cost?
from memory £500 . . . ouch
Bob
Here's a question for you - been thinking about getting one of these myself - do you just bolt the crown wheel and pinion to it and put it back in and off you go, or do you have to get it properly 'set-up' ????
Bit more to it - the quaife won't actually go in without filing ~3mm of ally off (about 15mins work) if you use a grinder the diff's full of
carborundum.... I put in new carrier bearings & seals but left the pinion setup strictly alone.
cheers
Bob
My diff was made from a 3.92 open and a 3.62 lsd. The guy at work that did it for me bolted a steel bar to the back of the diff (parallel to the
crownwheel) and measured ACCURATELY the distance to the back of the crownwheel. Took it apart the reassembled with the LS bit in the 3.92 case and
adjusted the output bearings to put it in the same place.
The car only moved under its own steam for the first time yesterday but i didn't notice any diff noise and knowing the guy who did it for me I
would have been surprised if there was.
photo in this thread..
Chris
[Edited on 17/10/05 by chriscook]
Liam hit the nail on the head, by leaving the pinion alone I only had to adjust the clearance (backlash) which is easy with the "castlated"
bearing carriers.
Bob
