On my X/Flow 1.6 I have an Aldon/Lucas side entry distributor.
I recently fixed a battery problem - I think and now the car won't start, since the winter. Have checked the usual things, have fuel at the
carb, wet plugs if I turn it over a lot, so have fuel in cylinders.
I have a good spark at the end of the distributor HT lead to earth, but can't see a spark at the plugs. Have checked and cleaned the distributor
cap contacts and rotor arm, but not sure what a worn distributor cap looks like.
I don't want to splash out on a new cap to then find that wasn't the problem.
Any thoughts?
[Edited on 9/3/14 by GeoffH]
A new rotor ran costs pennies , if you look inside the cap can you see what looks like pencil lines probably running from the center carbon brush out wards then the cap has had it
Check the distributor cap to make sure you still have the little carbon brush that contacts the rotor arm, and that the spring behind it is pushing it out.
I assume you've tried the spark by putting an earthed plug in the end of a plug lead.
Cap problems usually revolve around cracks in the cap so have a look around inside for any but your fault doesn't sound like that. They usually
result in misfires but not total loss of spark.
Could be the rotor. Does it have a resistor in it? It's usually embedded in resin between the centre and end contacts and these are known to
fail.
The rotor doesn't have a resistor but when I first looked at it, it was dirty at the contacts edge so I cleaned it up. Also cleaned the bit that contacts the carbon brush which works fine.
We have had loads of issues with the rotor arms on Xflows. Interpart ones especially. They just don't last.
Recently bought the red ones from the MGB owners club and not had a problem since.
