blade turbo headers
gaz_gaz - 11/5/14 at 01:18 PM
Hi guys.
I'm looking to have headers made to turbo a blade engine.
Any recommendations or anyone willing to help/do the job in exchange for pound notes?
thanks
mark chandler - 11/5/14 at 02:03 PM
I made mine from a chopped up stainless bike header, works well but has cracked so suggest you get it made in mild steel as less chance of it cracking.
It takes a long time to make them, if you get the mandrel bends, chop them up and hold everything together with gaffa tape I do not mind welding together.
What turbo you sticking on, come over and have a look at my setup if you want, I'll even take you out
Regards Mark
gaz_gaz - 11/5/14 at 05:02 PM
Thanks Mark,
My plan at the moment is to go with a TD04 from the 2.3 T5 or T5R Volvo.
Do you think this would be suitable? Only interested in running it at 8psi or so for now so i can stick with the standard head gasket and internals.
I've seen your link to the psycworks website for a lockup clutch should i require it.
dave_424 - 11/5/14 at 05:03 PM
I built my manifold from "butt-weld fittings" from www.zx55.com very good price
I used 1.25" schedule 10 bends in 304 stainless, then got some flanges laser cut from 304 also. Tigged it up and ended up with this for my TD04 turbo and 38mm external wastegate
[Edited on 11/5/14 by dave_424]
mark chandler - 11/5/14 at 05:25 PM
Mine was 7psi and delivered 201 BHP, it's now running around 8psi which is plenty fast enough.
The lockup clutch does not include the 1" spacer so you will also need to get one cut, my clutch started slipping at around 175bhp with Barnett h/d springs and OEM plates.
As you are running a water cooled oil fed turbo it will need to be mounted high enough for the oil to drain back into the sump, you can take an oil feed from the gantry where the pressure switch fits.
Losing heat is still a problem on mine, so dropping it out the side helps, I can TIG so if you assemble the bits like above I can join up for you including a bung in the sump. I do not have a flange on the bike end, just tubes from the original headers.
Regards Mark
[Edited on 11/5/14 by mark chandler]
