Having fitted my type 9 gearbox I find that there is a bit of movement on the chassis mounting evident with the movement of the gearstick. It could just be a tired rubber chassis mounting but I have done away with the very large dished washer that sits under the mounting and bolts through to the gearbox casing. In its normal fittin eg; Sierra, is it designed to prevent too much gearbox movement?
Either Westfield or Caterham , can't remember which, sell a heavy duty gearbox mount which is well worth fitting even if it involves a bit of fabrication
http://www.retrofordinternational.co.uk/mk1-gearbox-mount-2401-p.asp
These where the cheapest i could find when i wanted one there not a straight swap but can be made to fit
Jacko
[Edited on 14/6/14 by jacko]
The westy / caterham ones are off lotus elans and cortinas
Paul matty sportscars in bromsgrove sells them for £15
Good quality too
In which way is the gearstick moving? Are the engine mounts OK? The gearbox mounting does little more than hold the tail of the box up so any side to side movement under accelerating/decellerating would be due to soft engine mounts.
If the stick is moving up and down during accelleration/decelleration, then yes, a new gearbox mounting makes sense otherwise, the new gearbox mount will be masking a problem with soft engine mounts. The gearbox mounting is not there to prevent rotating movement.
For the little they cost its worth replacing them all
Its surprising how soggy they go over time
