Hi which fan switch should I use on a xflow with a 82 deg thermostat. Trying to bring the temp down a bit
What temperature is it running at? Mine sits at 72 all day if moving and about 85 stationary that's with a 68° stat form a jag and manual fan switch
Go to your local motor factors, they should have a listing for fan switches giving the fan on an off temperatures
My car was running at 90 to 95 and went to 100 if stopped for a minute. I have put in a 82 deg stat and was wondering what temp range on/off switch I would use that would operate with the 82 deg stat. Burton have a 95/90 or a 95/86. or is there another one that would suit better. I am using a vw expansion bottle in the system.
I have run X-Flows in Escorts and Caterhams, all had 74 degrees stats which was the standard Ford fitment. Sold my last spare on E-Bay, they went crazy for it. Was told they are no longer available. The engines ran at a rock solid 78 degrees on an accurate gauge. The Escorts always ran the standard viscous fans so no fan switch, on the Caterham I ran 86 degree switches along with a manual override.
With the engines at these low temperatures I'd be concerned that the oil isn't getting hot enough to boil off water that condensates inside the crankcase.
Originally posted by britishtrident
I hate when wrong info gets put on the net as fact.
Thanks for the information. I am using a fiesta thermostat housing which is 22x1.5 so will try and find one that is on at 90 and off at 87 and try that.
