Noticed this over the last couple of trips out, once warm the revs seem very slow to fall to idle from around 3k and also now idles at 1k when warm
when normally she sits around 900rpm.
Any ideas? She's a 2.0 black top twin 45 webers.
Air leak somewhere I would have thought
Check the obvious too - sticky throttle cable, something seized or binding in the linkages or throttle butterflies/shafts?
have you checked the carbs are balanced
Air leak....
Not too rich? Could try dropping the idle mixture screws 1/8 turn. Easy to put back if it isn't!
Carbs where balanced only a couple of weeks ago, I'm going to try the idle mixture screw next time I'm out but from what I have read
it's more than likely a air leak.
Is there a easy solution to finding this or would a smoke test be advisable?
And the answer was?
