Called DanST engineering yesterday, ali manifold with 40mm fitting kit arrived 1st class post today..
Stuck my Ebay R6 Carbs on .. Started first time
Took it round the block - running lean..
Stuck some match sticks in the air correctors - (if you squint & look you can see them) - AFR almost perfect ..
Mains have 155's - AFR's 12.5 to 13.5 even at WOT ..
Goes well - worn Yoko's stuck like glue - fab to be out n about again
