Here is my Duratec...
https://www.youtube.com/watch?v=Yapc3M4fRYM&feature=youtu.be
It's running on an MS3 at idle I've got the AFR at 14.5 and its looking not to bad, but as soon as I increase the revs....wait for the
smoke.....
On the video it is running lean at this point, but I've also run it ritcher and I'm still smoking.....
Any suggestions to help my diagnosis greatly appreciated...
Ian
Over fueling is black, oil is blue
Before worrying I would give it a good thrashing to free up rings and blow away any residual oil then try again.
Could be oil in the cylinders. which could be potentially bad! could be piston rings or valve head. Hopefully not damaged bores...
But it just looks like its not breathing well. Clogged intake.. check the carb also.
Tbh to be thats alot of smoke so id be thinking an oil leak into the combustion. Check timing first.if thats ok then check oil leak into exhaust then
youd b talking about possibly having to replace the head gasket and then the deeper stuff...
Have you taken any breathers to the inlet ? take your plugs out and check for oil on them. How was the engine stores it may have been on its side allowing oil into the bores
Mine was the same took pistons out honed bores and re ringed it piston ring groves were absolutely choked with crap and oil holes were blocked runs perfect now set or rings and gaskets not to dear.
Thanks All
Ian
