Dear Collective,
I am at the stage of plumbing in the engine for water on my build and have a quick query. I bought my engine, box, ecu from a running MK so should be
straight forward drop in and connect up.
I am not using a heater so that outlet from Thermostat should be blanked off, already done.
However the top outlet (bleed pipe?) from the thermostat is also blanked off, well it has some sort of bleed nipple on it.
Also the outlet (19mm?) from the thermostat which should link into the "bottom pipe" is also blanked off.
Would this work with this set up ? Please discuss.
Thanks in advance, Ian
Check out this thread :-
http://www.locostbuilders.co.uk/viewthread.php?tid=200665
Paul Turner's reply was a sound guide.
Thanks Dick,
I had read that thread but I am bemused by the ports that are blocked off on my thermostat currently as it was on a running setup. So it is basically
as Paul Turners image but without the Bypass pipe or the bleed pipe from the top of the thermostat and just wondered what thoughts were on that set
up, would it work ?
Thanks,
Ian
Originally posted by Lander
Thanks Dick, I had read that thread but I am bemused by the ports that are blocked off on my thermostat currently as it was on a running setup. So it is basically as Paul Turners image but without the Bypass pipe or the bleed pipe from the top of the thermostat and just wondered what thoughts were on that set up, would it work ? Thanks, Ian
