Im after one of these with 2 pipes one. does any one know where I can get one? 32mm wih 2 18mm or 16mm pipes.
pipe
Car Builder Solutions offer a 32mm with a tappable T if that helps?
linky
Cheers, Pewe10
Rover used a 32 -16-32 hard plastic Tee on the 75/ZT bottom rad hose.
ASH Hoses.
http://www.autosiliconehoses.com/
I dont believe what you are looking for alloy t-piece with two outlets exists off the shelf.
Option is use two t pieces or make one, either from scratch or from an existing t piece.
That's what im finding 02GF74. Tiger list one with 2 outlets but don't stock it any more.
My problem is I have a zetec and I need to put 2 pipes into the bottom hose. What have others used?
Use the original pump outlet hose (Mondeo). It has a T, then T again from that. Hope that helps
Pepperperformanceccose on eBay offer individual T with both 16mm and 19mm outlets.
I have asked them to quote for a one piece solution.
PM sent
