Morning all.
I have a set of the above with discs that are leaking, they had been played with in the past by unknown person. Titan keep no spares for these, any
help sourcing 4 butterfly's would be a great help. Not sure if any other make such as Weber would do the job. Any help or input gratefully
received.
If are just off centre you can slightly slacken of the screws that clamp the disc and snap the throttle open and closed a couple of times then hold
it closed while you are tighten the screws.
This works for SU and Weber carbs so should work on throttle bodies.
I am afraid it is more than this, I can get a 0.6mm feller gauge down the side of one of them. So would be impossible to balance and Un mappable.Really do need to source new ones or an alternative, of find someone who could make 4. Be a real shame to have to bin them for lack of the butterflies.
Sorry about the typos on above post, teach me to do it on my phone. I am sure you all know what I mean.
If you are sure they are not just badly positioned but have worn or been modified why not get new ones laser or water cut? You could take the best
fitting one photocopy/ convert to pdf/convert to DWG and there you go.....
I doubt whether anybody would file the edges of a throttle disk - that is the sort of fun we used to have with carbs.
Can you take out the spindles and see whether they seal without them?
Come to think of it isn't somebody from Titan a member on here? Perhaps you could beg for the CAD file?
Very helpful. Thanks. Believe me they have been filed.
Having now spoken to Titan, they just told me they had no spares, good bye. I have spoken with Jenvey and they were very helpful even though it was not their product. They have suggested that they have a look at butterfly and see what they can do re replacements. Now that's what I call service.
Do a member search using Titan as a search term. You will find Nick. He gives a personal e-mail address. I have seen many helpful posts from him. I am sure that if Titan cannot supply spares they would be able to provide a CAD file - or even a drawing.
What diameter is the choke? Discs are available for different diameter, both metric and imperial for SU, weber, dellorto carbs so it may be possible
to match. You may need to solder up the holes and drill thrm in correct place.
CAD drawing will give you disc shape but the discs, certainly SU have bevelled edge that you will not recreate by filing.
