Have a problem with the clutch slipping when on boost.
I have heavy duty springs fitted and only running 5psi.
Before turbo it behaved fine. Just wondering if I need new plates although the current ones only have 3 tho miles on them.
Any advice would be appreciated.
You will most likely need a lock up clutch.
The extra power on boost over standard power is too much for the clutch.
Something like this;
http://psycleworkz.com/#/on-line-shop/4558416390/2--stage-lock-up-clutch/763779
You'll also need to modify/spacer the clutch cover so it will fit.
Just joined and saw your post. Another option is NLR Boost Compensating Lock Up Clutch.
https://store.schnitzracing.com/nlr-boost-compensating-lock-up-clutch-suzuki-gsx1300r-hayabusa-99-15/
Expensive as heck though I'd think it's the perfect application.
Billy
I fixed it with a set of new original clutch plates. Now running 7psi with no problems.
Cheers Peter
Cheers Peter
Cheers Peter
I think it could be on borrowed time though![]()
Cheers Peter
No if he drives like Miss Daisey.
Drive it like its stolen.Did Austrian alps last year , and plenty of weekend blats , not a problem. Thanks for all the advice.
