I can buy helical LSD's quite cheaply (comparatively speaking & providing I buy several at a time) but they are only available as standard
for the English & Atlas axles, which I assume are only live axles, not independent.
That in itself wouldn't bother me as I want them to use in a chain drive diff, so would make my own bearing carriers etc., but the English is a
22 spline & the Atlas a 16 spline, are these spline setups the same as any later Ford independent axle diffs, in other words, are there any Ford
driveshafts with c/v's or pot joints that could be used with those diffs or is all the later stuff completely DIFFerent (see what I did there?
The early sei westifelds used a english diff/cwp in an alloy housing, i don't know what drive shafts they are paired with.
Dave
The Westfields used their own cases and special output shafts in their early independent rear ends.
Why not by ib5 type. Takes all fiesta escorts drive shafts ect
Lotus Elan used english diff in lotus housing. So splined output shafts are available. Shame they will cost a lot more than any discount on your diff,
don't know of any others.
Mick
Found this - may be the same as the ones you are looking at but for a landrover, think they had splined drive shafts as well -
http://www.ashcroft-transmissions.co.uk/limited-slip-differentials/ashcroft-atb.html
You might also find some inspiration on here as well - http://chaindrivediff.co.uk/about/home/shop/
[Edited on 7/12/16 by Ugg10]
Don't actually need any inspiration, we already have our own chain drive diff using the Toyota donor diff, but I was looking for a cheap way of
doing a LSD & a supplier coincidentally offered me these diffs.
Just need a way of using one of those diffs with ordinary driveshafts rather than solid halfshafts :s
If anyone is interested in the diffs for English or Atlas setups I could see if we can get a group buy together, if anyone's interested then u2u
or email me at russbost at googlemail dot com
English LSD
[img]
English LSD
[/img]
Atlas LSD
Atlas lsd
To be able to do the prices I have listed above I need to get at least 5 orders for whichever diff (if I can get half a dozen combined that would also
do it)
The cheapest option is to strip out a Sierra LSD as all the LSD bits are in the housing the crown wheel bolts too.
Yes I know it's a viscous diff but it's the cheapest option and will take Sierra shafts
Look what just popped up on eBay
Ford English LSD 22-Spline Differential Helical Traction System, Blackline Gears
