Zetec ST170 Cylinder head refurb
Barksavon - 22/7/17 at 01:49 PM
I'm putting a ST170 engine in my Avon. I think the mileage of the engine is around 145000 so I'm considering taking the head off and refreshing the valve seats etc. I'm using a Haynes manual for a standard zetec and am a bit confused over one issue. At present I've set No 1 cyl to TDC on the compression stroke (as per the haynes) and got the crank
locked with the pin and the cams locked with the 5mm bar, I've taken the timing belt off. The manual states that the intake and exhaust cam lobes of no 1 cylinder will be pointing upwards (though not vertical) and the valve clearances can be checked. Does this make sense?
The lobes of no 1 cyl cams on my engine at present are pointing out to each side of the cyl head.
Am I doing summat wrong , is the manual wrong or is it different for the ST170(apart from the fact the ST170 has the vvt)
Any advice etc very welcome
Ian
[Edited on 22/7/17 by Barksavon]
chris - 22/7/17 at 06:10 PM
if you have the haynes zetec manual then the valve clearence measurements will be wrong any way the zetec engine has shims and the st170 has solid machined lifters which can only be adjusted by an engineering shop if you have the engine at tdc and the cams locked then thats correct when taking camshafts off i would number everything including the lifters cos they are machined to fit that valve
snapper - 23/7/17 at 07:30 AM
The cam rotates at half the speed of the crank so you may need to rotate the crank 1 more time to get the cam in the right position
Barksavon - 23/7/17 at 09:02 PM
Thanks for the replies. Didn't know about the machined lifters on the 170 engine so that's very useful. I did try turning the crank further but as far as I can see the bar that locks the cams in place only fits in one position in a complete revolution because the slots in the ends of the cams are offset....?
chris - 23/7/17 at 09:20 PM
yes thats correct the cams will only lock in one position you will have to excuse snapper paul he is only just about to make the move into modern engines lol
you may find the locking bar might not fit cos the inlet cam may be advanced a little due to it not returning to the retarded position fully
[Edited on 23/7/17 by chris]
Barksavon - 23/7/17 at 09:30 PM
Snappers not the only one making his first move into modern engines... I'm fine with a pinto or an a series, fuel injection and vvt is a completely new ball game for me and I'm getting on a bit now, hence every bit of advice is invaluable...☺
Thanks very much
Ian
chris - 23/7/17 at 09:47 PM
solid lifters means it can rev higher than a standard zetec
chris - 23/7/17 at 09:49 PM
i use the term modern engine loosely the zetec and st are 20 years old approx
coozer - 24/7/17 at 11:52 AM
Inlet cam on the st170 can float aboit a bit when theres no oil pressure ie not running.
Barksavon - 24/7/17 at 06:01 PM
Can anyone tell me, Do i need to take the camshaft pulleys off to remove the cams and what do I do with the vvt unit, I can't take the head off with cams in situ
rusty nuts - 24/7/17 at 07:26 PM
Whatever you do do not use the camshaft timing tool to hold the cam whilst slackening or tightening the pulley bolts, use a proper cam pulley holding tool . Not sure if the normal type fits the inlet cam on your engine though.
Barksavon - 24/7/17 at 09:07 PM
No the tool won't work on the ST170 inlet pulley
